Dabar yra 2024 05 29, 02:17. Visos datos yra GMT + 2 valandos.
Forumas » Informacijos kaupikliai » Nauju SSD kokybe
Nauju SSD kokybe |
Parašytas: 2023 08 25, 14:15 |
Ibanez rašo: |
Vat Mari supratima savo ir parode, SAS ssd visada yra gerokai brangesni..
Tuscia cia diskusija, kai zmogus tik nori pasipiktinti kad pigus slamstas nelaiko. Nereikia noreti, kad buitinis ssd dirbtu gerai 24/7, jie tam nepritaikyti.
Pats savo suvokima rodai... Ir dar rashai, kad diskai turi nelaikyti? O kodel jei jie operacinkej niekas ten nevyksta
Susiradau ta serva kur klientui suderinom, ten yra pasirinkimai, kainos svarais dirbu UK
SAS SSD
800GB SSD SAS ISE, MU, up to 24Gbps 512e 2.5in with 3.5in HYB CARR, AG Drive
£1,024.60 /ea.
800GB SSD SAS ISE Write Intensive 12Gbps 512e 2.5in with 3.5in CARR AG Drive 10 DWPD
£2,522.66 /ea.
1.6TB SSD SAS ISE, MU, up to 24Gbps 512e 2.5in with 3.5in HYB CARR, AG Drive
£1,385.56 /ea.
1.92TB SSD SAS ISE, RI, up to 24Gbps 512e 2.5in with 3.5in HYB CARR, AG Drive
£1,019.24 /ea.
1.92TB SSD SAS ISE Read Intensive 12Gbps 512 2.5in Hot-plug AG Drive,3.5in HYB CARR, 1 DWPD
Matai kiek SASai kainuoja?
Dabar SATA
SATA SSD
480GB SSD SATA Read Intensive 6Gbps 512 2.5in Hot-plug AG Drive,3.5in HYB CARR, 1 DWPD
£320.10 /ea.
480GB SSD SATA Mix Use 6Gbps 512 2.5in Hot-plug AG Drive,3.5in HYB CARR, 3 DWPD
£454.04 /ea.
960GB SSD SATA Read Intensive 6Gbps 512 2.5in Hot-plug AG Drive,3.5in HYB CARR, 1 DWPD
£466.09 /ea.
960GB SSD SATA Mix Use 6Gbps 512 2.5in Hot-plug AG Drive,3.5in HYB CARR, 3 DWPD
£733.96 /ea.
1.92TB SSD SATA Read Intensive 6Gbps 512 2.5in Hot-plug AG Drive,3.5in HYB CARR, 1 DWPD
Kainos be PVM (VAT)
Servas PowerEdge R750xs |
Nauju SSD kokybe |
Parašytas: 2023 08 27, 23:17 |
Ibanez rašo: |
SAS SSD
£1,024.60 /ea.
£2,522.66 /ea.
£1,385.56 /ea.
£1,019.24 /ea.
Dabar SATA
SATA SSD
£320.10 /ea.
£454.04 /ea.
£466.09 /ea.
£733.96 /ea.
Kainos be PVM (VAT)
normalios tos kainas, enterprise level hardvaras kainuoja daugiau nei consumer grade, ju ir patikimumas kitoks.. cia tas pats kas lyginti quadro ir rtx VGA.. |
Nauju SSD kokybe |
Parašytas: 2023 08 28, 13:04 |
Ibanez rašo: |
Jau rashiau, kas nutiko nusipirkus Intel firminiu serveriniu motininiu, daugiau pavyzdziu galeciau.
Kai kokybe prasteja tai kuri laika dar lieka "vardas" ir kainos. Po to zhmones pastebi, kad visa tai afera. Tai tik bereikshmis vardas su ishpusta kaina.
Sakysim SATA SSD aprashyta, kaip kazhkoks aukshto patikimumo gaminys. Juk to NEPATIKRINSI, ant kiekvieno sh galima uzhdet ir kokybes zhenkla ir prirashinet fantaziju apie HIGH tech.
Bet sakysim caddy serveriniams HDD. UK Dell kazhkoki kosmosa lupa, tai vis perka kinishkus ir deda.
Toliau tie HDD jau gamintoju yra klasifikuojami pagal patikimuma ir optimizacija naudojimui
pvz WD,
WD Blue WD Purple WD Red WD Black WD Gold
Dar buvo WD green
Ka cia kazkoks Dell gali naudingo ineshti? Nieko, bet va ir cia prirasho fantaziju ir uzhlauzhia kaina |
Nauju SSD kokybe |
Parašytas: 2023 09 02, 07:26 |
Na kiek pirkau jau kaip čia sakote pigesnių SSD, visi atlaikė po savo garantinį. (3 metus). Brangių ir nepirkau. Pvz kiek jų teko naudoti tokių kaip Adata, Silicon Power, Kingstom (128 - 240 GB) tai tik vienintelį kartą pasitaikė kompas remontui, kad SSD jam labai jau ten sublūdijo (Adata SU650, 120 GB). Situacija buvo tokia, kad ijungus kompą, (nežinojau ar jame HDD ar SSD) užkrovimas nevyksta, kompas bando tvarkyt diską, vis prašo Windows repair, žodžiu mintis pirma, diskas . Taigi išsiardau išsiimu tą SSD pajungiu ant savo stacionaraus irgi lūžinėja. Bandymas formatuot per savo kompą USB su Windows kompas sminga. Tai paskui, kažkuria diena, taip galvoju dar pabandysiu pasižaist. (Tam laptopui aišku nupirkau kitą SSD idejau sutvarkiau win atidaviau kaimynui) ir ką - SSD pavyko suformatuot, su programa patikrinau gyvybę (CristalDiskInfo) klaidų jokių darbo valandų nedaug, ir ką įdėjau į kitą kompą normaliai susidiegė operacinė ir viskas ėmė veikti... tai va. O daugiau tokių gedimų ir nepasitaikė . Pirkau nesenai du SSD po 128 GB SP, abu tikrai gerai veikia o kaina juokinga 12 eurų vientas... (Topo centre pirkta) . Ir žinau kad jie atlaikys garantini naudojant 3 metus |
_________________ Ne vergas, ne karalius, tik žmogus... |
Nauju SSD kokybe |
Parašytas: 2023 09 11, 19:56 |
Kadangi pats nelabai bandžiau, žinau, nelabai ir daug kažkur gilinausi. O čia vykstant pokalbiui apie tai turiu klausimą. Jei kompiuteryje sukasi SSD su sakykime atminties kiekiu kuris netenkina ir norisi prasiplėsti ją, o yra galimybė įsikelti gali būti ir HDD ir SSD (gamintojo informacija, o pats šito nepasakysiu, neardžiau kompiuterio ir neketinu, tad nežinau), o ir kišenėje ne milijonai. Vadinasi kaina turi įtakos. Nebūtų blogai jei HDD, o ne SSD? Kurie man atrodo pigesni. Vienas SSD suktūsi jau - gamintojo įdėtas. Tiesa dabar kainų neatsiminsiu, senokai žiūrėjau. Tai galiu ir sumaišyti kažką. Gamintojas pats negali pasakyti, nes kompiuterio modelių daug variantų, garantinis siūlo atsivežti apžiūrai ką jie ten galėtų pasiūlyti ir pan., kas kaip suprantu kainuoja. Klausimas bendram suvokimui ir t.t. |
Nauju SSD kokybe |
Parašytas: 2023 09 11, 21:53 |
F4T4L1TY rašo: |
HDD siais laikais jau bus per letas variantas, tikrai vargu ar tiks. Ilgai krausis. WinXP laikais tai tiko.
laptopuose dabar paprastai tik vienam yra vietos, tai ten reikes didesnio, o paprastuose kompuose papratsai isidedamas papildomas. Siulau is karto deti bent 2TB. |
Nauju SSD kokybe |
Parašytas: 2023 09 11, 22:48 |
Tai va tame ir klausimas, nes SSD yra, jis sukasi greitai (Win 11 juose), o HDD būtų dėl atminties failams saugoti, kad perinstaliavus kompiuterį jame neišsitrintų failai, plius kaina man atrodo HDD žemesnė. Kaip sueitų toks variantas? Vietos pagal gamintoją supratau gali būti vienam dar SSD/HHD arba RAM'ams. Reikia ardyti kompiuterį. Yra dar garantija, bet viskas veikia gerai. Tai negaliu pats ir per didžiausius norus ir nešti į autorizuota man atrodo kainuos, nes tai ne gedimas. O tik papildomos detalės. O ten jau nelauks kol apsispręsiu ko noriu ir niekas neaiškins kas geriau Tobulinti galima iki 1TB lyg ir arba 32 GB RAM. O ir dviejų nereikia. Užtektų iki 1TB arba net papildomų 512GB. Nes ne kraunamas visas gyvenimas kompiuteryje. Bet šiai dienai šiek tiek trūksta atminties. HDD sukosi ne tik XP, turėjau su 8 - tais pre-installed. Viskas veikė super gerai. Tik pradėjus atnaujinti dirbtinai į 10, 11 Windows jau stabdė. Dar užkrovus kokią antivirusinę. Dėl paprastų kompiuterių nesutinku, kaip tik pigiausių variantų nelabai leidžia tobulinti gamintojai, kiek bent žinau aš ir matęs. O galimybės kažką papildomai įsimesti eina tarkim tokiuose kaip žaidimų kompiuteris. Nebent pagal patį žaidimų kompiuteris yra paprastas variantas, kur kaip tik viskas turi suktis gerai? |
Nauju SSD kokybe |
Parašytas: 2023 09 12, 08:08 |
šiai dienai šiek tiek trūksta atminties |
vadinasi, susiklostė supratimas, ko norisi.
Siūlau tiesiog parduoti turimą kompą, pagal pasakojimą jo būklė labai gera.
hdd jau atgyvena, dabar ryškus postūmis SSD rinkoje, bus kaip su LCD buvo. |
Nauju SSD kokybe |
Parašytas: 2023 09 12, 10:15 |
F4T4L1TY rašo: |
Apie kokia talpa eina kalba? Kaina is esmes per mazai skiriasi, kad butu verta galvoti apie HDD. PVZ jeigu sata:
Samsung SSD 870 kainuos 100eur~ 2TB
WD Blue HDD 5400rpm!!! kainuos kokius 70eur 2TB
Ar verta svarstyti del ~30eur? |
Nauju SSD kokybe |
Parašytas: 2023 09 12, 11:12 |
o dar kiniečiai raunasi į rinką su savo gaminiais. Atsimenant istoriją apie laikrodėlius žadintuvus, paskiau Android telefonus, dabar galima tikėtis lūžio SSD rinkoje. Xiaomi 64TB už < 40
klausimas, ar pavyktų instaliuoti operacinę sistemą, nes NTFS nepalaiko ...
Lenovo 128TB < 20 |
Nauju SSD kokybe |
Parašytas: 2023 09 12, 12:31 |
a1girdas rašo: |
Xiaomi 64TB už < 40 |
Paskaityk ten komentarus, tiesiai šviesiai rašo jog apgaudinėja: perki 64TB, gauni 1TB
Niekada pas kiniecius nepirk SSD, 99% jog apgaus. Vienas procentas gal neapgaus, bet reikia turėti daug shopinimosi patirties kad atskirti vieną nuo kito. |
Nauju SSD kokybe |
Parašytas: 2023 09 12, 14:04 |
a1girdas rašo: |
Kompiuteris geras, eina puikiai. Atminties trūkumas, nes yra 512 GB tik jos. O tai žaidimų kompiuteris. Nesu žaidimų gerbėjas, bet kartais visko būna. O žaidimai užima geresni daug. Tai mintys į ateitį tiesiog prasiplėsti iki 1 TB (papildomas 512 GB SSD/HDD) arba iki 1.5 TB (papildomas 1 TB SSD/HDD). Plius RAM'us didinti iki kažkiek. Maksimaliai galima iki 32GB, šiai dienai užtenka ir esamų 8GB. Kompiuteris nėra senas, metai, bet iš karto perkant ir žinant informaciją apie jį buvo minčių, kad gal reiks pasididinti atmintį iki tiek, kad ateityje nebūtų problemų dėl to. Keisti nieko nereikia. HDD minimi tik dėl kainos. SSD faktas, kad geriau, bet talpinti ir laikyti, kad ir foto ir pan. gi nereikia ten geriausio SSD, nes kaip minėjau Windows sukasi SSD. Tiesa dar nesu 100 proc. tikras, kad aplamai jis galimas, HDD turiu omenyje. Nes gamintojas pateikė tik apytikslę informaciją, realiai variantus kurie gali būti. Tiek mini slotus RAM'ų, tiek atminties abiejų rūšių. Beje SSD 512 GB - 1 TB kiek gali kainuoti geresnio gamintojo ir įdėjimas? Jei atmesti HDD. Autorizuotas servisas to neatskleidžia. Siūlo atvežti apžiūrai. Gal kas susidūrėt?
Ibanez rašo: |
Rimtai tokios kainos? 2 TB 100 eurų? Tai aišku neverta dėl tiek pirkti HDD. O kiek gali kainuoti keitimas? Kaip minėjau talpos prie esamos 512 GB + 512 GB arba 1 TB, tiksliai nežinau kiek maksimaliai galima. Man ir bendroje sumoje 1 TB užtektų, 1.5 TB jau būtų tobula. Aš mažai dar domėjausi šiuo reikalu, gamintojas kompiuterio ir ten tiksliai nieko neišdėstė. Kaina iki 100 eurų aplamai būtų gerai. Įdomu kiek servise keitimas dar gali kainuoti? Nes garantinis, pats nieko daryti negaliu, serviso rekomendacijos. Turiu laikytis jų. O ir nelabai darau tą, tai būtų tas pats kaip koks virtuvės šefas prie mašinų remonto
Nepatariu saugot failu kompe esanciame SSD. Ishjungus maitinima staiga -SSD viskas gali labai korumpuotis. su HDD tokiu nesamoniu nebudavo, susigadindavo tik gal vienas failas max. |
Yra daromi ir kitur back up'ai, bet čia ir dabar yra sukelta į kompiuterį failai. SSD girdėjau apie šiokį tokį trapumą, va kodėl ir HDD vis dar minimas. Bet kaina kaip ir įtakoja labiausiai. Bet kaip minėjau yra ir kitur dar pasidaromos kopijos. Nes aplamai yra atvejų kada besinaudojant social. medija kažkada tiesiog akyse nieko nedarant užgeso kompiuteris ir neatsigauna, beje su HDD. Tai dabar yra daromos po kelias kopijas aplamai dėl saugumo.
Čia kur taip? |
Nauju SSD kokybe |
Parašytas: 2023 09 12, 15:50 |
Ibanez rašo: |
Lexar 2TB pas mane normaliai veikia, dabar kainuoja 75
https://www.skytech.lt/lnq100x1920rnnng-lexar-ssd-nq100-1920-ssd-form-factor-ssd-interface-sata-iii-wri-p-630357.html
Tas pigus lexar neturi DRAM. SSD be DRAM, kaip vyras be kiausu
imtai tokios kainos? 2 TB 100 eurų? Tai aišku neverta dėl tiek pirkti HDD. O kiek gali kainuoti keitimas? Kaip minėjau talpos prie esamos 512 GB + 512 GB arba 1 TB, tiksliai nežinau kiek maksimaliai galima. Man ir bendroje sumoje 1 TB užtektų, 1.5 TB jau būtų tobula. Aš mažai dar domėjausi šiuo reikalu, gamintojas kompiuterio ir ten tiksliai nieko neišdėstė. Kaina iki 100 eurų aplamai būtų gerai. Įdomu kiek servise keitimas dar gali kainuoti? Nes garantinis, pats nieko daryti negaliu, serviso rekomendacijos. Turiu laikytis jų. O ir nelabai darau tą, tai būtų tas pats kaip koks virtuvės šefas prie mašinų remonto |
Prasom kaip pvz:
https://www.skytech.lt/mz77q2t0bw-samsung-ssd-870-qvo-2tb-sata3-25inch-sata-iii-p-514673.html
Bet jeigu PC toks jau ne senas, gal yra M.2 jungtis? Labai didelis skirtumas butu:
https://www.skytech.lt/asx8200pnp2ttc-adata-xpg-sx8200-pro-ssd-2tb-pcie-gen3-2280-35003000-mbs-p-463464.html |
Nauju SSD kokybe |
Parašytas: 2023 09 13, 13:06 |
Nežinau. Pats neardau kompiuterių, nėra tiek žinių ir kompetencijos aplamai ta sritimi. O ir negaliu, yra garantija. Servisas ims pinigus už kažkokius tikrinimus ir t.t. Kompiuteris lyg 2021 metų modelis. Pirktas 2022. Nepasakysiu tiksliai šios informacijos, nes nežinau ir duomenų tikslių.
O Samsung geri SSD? Nes aš pats ir kažkada žiūrėjau į juos tik galvojau ar tinka ne Samsung kompiuteriui, nebūtų kokių nesklandumų naudojant kito gamintojo? Kažkada teko girdėti nuomonių, kad ne visi tinka visiems kompiuteriams? Nieko apie tai nežinau. |
